[GRASSuser] [GRASSLIST:1006] Re: nviz error in grass61
Thu May 4 20:55:06 EDT 2006
Alessandro Bigi wrote:
> I have a Grass61 cvs just compiled on a Sarge-2.6.8-686.
> When I run a nviz session, the monitor is empty and the terminal says:
> Xlib:  extension "XFree86-DRI" missing on display ":0.0".
Try "export LIBGL_ALWAYS_INDIRECT=1".
> However I can load previous nviz sessions made with grass60.
> Am I missing some lib? I tried to correct the DRI section in
> /etc/X11/XF86config as Markus once suggested, but that did not help.
The OpenGL library is trying to use direct rendering but the X server
doesn't support it. It /should/ fall back to indirect rendering; I
don't know why it doesn't.
