[GRASSLIST:1030] Re: GRASS and vector lines: how can I change the direction of digitized lines?
wqual wolfgang.qual at gmx.net
Mon May 8 03:00:17 EDT 2006
Good Morning Otto, hi list.
thank you very much for this hint. BTW, I found out that the mapserver needs a
special option specified to display the direction correctly (see [1] for
details]: GAP must be set to something negative.
Best regards,
Wolfgang
[1]
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0310/msg00441.html
---8<----------------------------------------------------------------
Am Freitag 28 April 2006 pH:00:14 nachmittags/abends schrieb Otto Dassau:
> Am Freitag, 28. April 2006 13:35 schrieb wqual:
> > Hi GRASS list,
> > I have two shapefiles which represent the average traffic load for some
> > streets in Munich. The traffic is divided into "incoming" and "outgoing"
> > traffic.
> > What I would like to do: display this map in my mapserver application
> > (using ttf-arrow symbols).
> > However, mistakes were made during digitizing, thus the direction of the
> > lines is wrong (looks like this
> > and should be something like
> > Therefore my question(s):
> > a) is it possible to display these directions within GRASS (I tried to do
> > this in ArcView before)
> Hi Wolfgang,
> the parameter in d.vect is display=dir
> e.g.: d.vect roads display=dir,shape
> > b) how can I change the direction of the lines in GRASS?
> as far as I know you can't, because you define the direction when you
> digitize a line from node a ---->----- node b. But you can use columns in
> the appendant attribute table to assign different values for each direction
> (e.g. speed).
> see ->  g.manual v.net.path
> afcolumn   Arc forward/both direction(s) cost column
> abcolumn   Arc backward direction cost column
> regards,
>   Otto
> > I would be most grateful for some comments on this issue.
> > Best regards,
> > Wolfgang
