[GRASSLIST:1042] Re: openstreetmap data import into GRASS
Glynn Clements
glynn at gclements.plus.com
Mon May 8 17:41:49 EDT 2006
Hamish wrote:
> problem:
> while [ $ERRORCODE -eq 0 ] ; do
> read LINE
> ERRORCODE=$?
> test $ERRORCODE && continue
> if `echo $LINE | grep` ; then
> do_minimal_stuff()
> fi
> done < 100mb_file.txt
> bash takes 800mb ram (that's ok, I've got lots, no swapping) but runs
> *incredibly* slowly. Like 80486-SX slowly.
> why is that? What's a better way of working through lines containing
> spaces? Set the file as a fd to pass to `read` instead of via redirect?
Spawning one grep process per line isn't particularly efficient.
What is that test meant to do?
