[GRASSLIST:1043] Re: patched rasters
    Glynn Clements
    glynn at gclements.plus.com
    Mon May  8 17:44:13 EDT 2006
Stuart Edwards wrote:
> Your proposed process cleared up the fuzziness nicely but there were
> some unintended consequences.  The r.composite image had >32,000 new
> 'colors'.  I used i.group and i.cluster to sample the data back to
> something reasonable.  255 was an improvement, but still too hard to
> match a color table.  Using 4 categories (the original map was
> printed in blue, brown and black on white) was a big improvement, but
> the brown and blue were indistinguishable.  Long story short, I went
> back to a graphics program to patch the two sheets and then
> reimported them.  Simple really.  Lesson learned is that patching
> scanned color graphics is better accomplished in something other than
> GRASS as a pre-process!
An alternative approach would have been to start by using a graphics
package to give all the source images the same colour palette.
