[GRASSLIST:1051] Re: vector map <-> db connection
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Tue May 9 11:39:07 EDT 2006
did you run db.connct?
do you have the correct permission on the dbf file?
hello,
max
Stefán István wrote:
>Hello List!
>I have problem connecting a vector map to a database.
>I created a vectormap by the v.digit command, and then I would like to add
>some information to the digitialized points.
>I created a db connection with this command:
>GRASS 6.1.cvs (Ferencvaros):~ > v.db.connect -o map=kietmelo_kutak_1
>driver=dbf table=kutak1
>WARNING: Table <kutak1> does not exist in database
> <$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/>
>WARNING: The table <kutak1> is now part of vector map <kietmelo_kutak_1>
> and may be deleted or overwritten by GRASS modules.
>Then I tried to add columns, but I got error message:
>GRASS 6.1.cvs (Ferencvaros):~ > v.db.addcol map=kietmelo_kutak_1 columns="nev
>varchar(10)"
>DBMI-DBF driver error:
>Table 'kutak1' doesn't exist.
>Error in db_execute_immediate()
>ERROR: Error while executing: "ALTER TABLE kutak1 ADD COLUMN nev
> varchar(10)
>ERROR: Cannot continue (problem to add column).
>What did I wrong?
>Thanks for the help in advance,
>Istvan
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
