[GRASS-user] Re: [GRASS-dev] More efficient to use r.mapcalc or
r.patch in a l oop for creating mosaics?
Cedric Shock
cedricgrass at shockfamily.net
Thu May 11 16:21:02 EDT 2006
Eric,
There's no point in trying to sort the inputs to r.patch. It'll only increase
the speed by a small amount (it'll take more than half as much as the maximum
time at best). It's pretty much guaranteed that the row skipping optimization
will never apply on mosaic problems anyway because almost every row will have
one null in it either from the input data, from slight gaps between input
patches, or the most common: gaps between the input patches and the edge of
the region.
I'd guess that r.patch is faster than mapcalc due to specialization. It could
easily be much faster to export the maps and use gdalwarp to compile them
together (assuming gdalwarp iterates over each input map seperately) and
re-import the result as Maciek suggested.
--Cedric
