[GRASS-user] Redirecting output from Grass commands in bash script
Soeren Gebbert
soerengebbert at gmx.de
Fri May 12 16:42:08 EDT 2006
if you are using the bash try this:
r.mapcalc 'map=sin(row())' > /dev/null 2>&1
Soeren
Jeroen Wortel schrieb:
> Hi All,
> I want to surpress the output of some Grass commands when using a
> script, by redirecting it to /dev/null.
> I use:
> null=/dev/null
> r.mapcalc 'map=etcetc' >> $null
> Some of the output gets redirected, but some still appears on screen.
> How can I redirect the other output as well?
> ADThanksVANCE,
> -Jeroen.
>_______________________________________________
>grassuser mailing list
>grassuser at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grassuser
