[GRASS-user] grass prompt -- strange behaviour
Glynn Clements
glynn at gclements.plus.com
Mon May 15 04:16:35 EDT 2006
Martin Landa wrote:
> there is something strange with GRASS prompt on my computer (Debian
> GNU/Linux unstable, UTF8). An example script:
> for map in $(ls *.xml); do echo "$map -> ${map%%.xml}"; done
Why the "ls", rarther than just:
for map in *.xml ; do ...
> GRASS not running
> $ for ...
> abscl-seidl.gkf.xml -> abscl-seidl.gkf
> abscl-temelin.gkf.xml -> abscl-temelin.gkf
> bug-1.3.25-zpk.gkf.xml -> bug-1.3.25-zpk.gkf
> zoltan-test_2d_gon.gkf.xml -> zoltan-test_2d_gon.gkf
> zoltan-test_3d_dms.gkf.xml -> zoltan-test_3d_dms.gkf
> zoltan-test_3d_gon.gkf.xml -> zoltan-test_3d_gon.gkf
> -> OK
> GRASS running ...
> GRASS > for ...
> abscl-seidl.gkf.xml -> abscl-seidl.gkf.xml
> abscl-temelin.gkf.xml -> abscl-temelin.gkf.xml
> bug-1.3.25-zpk.gkf.xml -> bug-1.3.25-zpk.gkf.xml
> zoltan-test_2d_gon.gkf.xml -> zoltan-test_2d_gon.gkf.xml
> zoltan-test_3d_dms.gkf.xml -> zoltan-test_3d_dms.gkf.xml
> zoltan-test_3d_gon.gkf.xml -> zoltan-test_3d_gon.gkf.xml
> So, ${map%%.xml} does not work any more, overmore there is a strange
> last line containing empty variable $map.
> Am I doing anything wrong? I am a little bit confused;-)
My first suspicion would be that the session startup is changing
either which "ls" command is used or the behaviour of the "ls"
command. Everything except for "ls" is a shell built-in.
