[GRASS-user] cannot run grass
Mon May 15 22:32:42 EDT 2006
orkun wrote:
> I cannot run grass and gets this message:
> orkun at landslide:~$ grass60 -text
> Cleaning up temporary files.....
> Starting GRASS ...
> ERROR: LOCATION_NAME not set
> /usr/local/grass-6.0.1/etc/Init.sh: line 541:
> /usr/local/grass-6.0.1/etc/lock: No such file or directory
> Unable to properly access /usr/local/grass_Data0/bartin/orkun/.gislock
> Please notify system personel.
> can you tell me what migth happen ?
Your GRASS installation is incomplete.
If you compiled it yourself, check the output from "make" for error
messages during the compilation of the lib/init directory. If you are
using pre-compiled binaries, report the issue to whoever created the
binaries.
