[GRASS-user] Data interchange file format
Markus Neteler neteler at itc.it
Tue May 16 08:22:28 EDT 2006
Tyler Mitchell wrote:
>If it is an .e00 file (arcinfo interchange format), then you have a
>couple options (one was already mentioned).  I normally use a set of
>tools called avcimport [2] to "import" the .e00 file into a coverage
>format.  Then I use OGR tools [3] or GRASS v.in.ogr to import the data
>into GRASS or other formats [4].
... or simply use v.in.e00 :-)
v.in.e00 help
Description:
 Import of E00 file into a vector map.
Usage:
 v.in.e00 [-v] [--o] file=string type=string [vect=string]
Markus
