[GRASS-user] Trento3D screenshots redone
Dylan Beaudette
dylan.beaudette at gmail.com
Thu May 18 21:54:43 EDT 2006
On Thursday 18 May 2006 18:04, Hamish wrote:
> > > > How would you go about adding 3D objects like trees? Or are you
> > > > only dreaming?
> > > http://les-ejk.cz/?cat=grass
> > > Not dreaming... :D
> > Neat module Jachym !
> > g.region res=4
> > r.mapcalc "trees= if(ndvi >= 0.5, 1, null())"
> > g.region res=8
> > r.to.vect in=trees out=trees_pts feature=point
> > g.region res=4
> > v.trees3d in=trees_pts out=t3d elevation=elev_4m oak=50 pine=50 \
> > spruce=0 nviz elev=elev_4m color=ikonos.rgb vect=t3d
> > output:
> > http://169.237.35.250/~dylan/temp/pinn_trees.jpg
> I see your trees are in geometric lines. For a more natural looking
> picture I would suggest perturbing your vector points (v.perturb) by
> a random amount up to about 1/2 of the initial raster resolution.
> Hamish
Hamish:
yet again your sage advice saves the day. Thanks for the tip!
completely forgot about that command...
I'll try it tomorrow and post the results.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
