[GRASS-user] Trento3D screenshots redone
Thomas Adams
Thomas.Adams at noaa.gov
Fri May 19 10:57:00 EDT 2006
Markus,
I understand about the modeling vs r.lake. I guess I just took the
opportunity to make the GRASS community aware of the modeling
possibilities and the possible direction we may go in the NWS. I really
don't know anything about the SWIG interface; can you explain how it
could be helpful in this application?
Regards,
Tom
Markus Neteler wrote:
> Tom,
> I didn't intend to make some real hydrological modeling. r.lake
> isn't written for that.
> In fact, it will be a good idea to connect to external models.
> E.g. the SWIG interface could be of help here.
> Markus
> On Fri, May 19, 2006 at 09:49:41AM -0400, Thomas Adams wrote:
>> Paulo,
>> You're right about the need for modeling. Actually, the modeling would
>> be done outside of GRASS and then have the appropriate water surface
>> elevation data imported into GRASS to show the inundated areas. The
>> hydraulic modeling *could* be done withing GRASS, but a better first
>> step probably would be to do the modeling outside of GRASS and then
>> import the data. An additional advantage to this is that there are many
>> hydraulic models and one may have a preference as to which to use or,
>> not be restricted to a particular model, thereby retaining more flexibility.
>> Tom
>> pmarc wrote:
>>> 2006/5/19, Thomas Adams <Thomas.Adams at noaa.gov>:
>>>> Hamish & Markus,
>>>> How did you do the inundation? With r.lake; does this use a level
>>>> surface? If so, this is not correct for a river, due to the downstream
>>>> slope of the topography and the hydrodynamics of the flow. The resulting
>>>> water surface elevations would be less than a level surface. Channel &
>>>> overbank cross-sections are needed (corresponding to those used in a
>>>> dynamic flow model) which then need to be intersected with the
>>>> topography. The US Army Corps of Engineers HEC-RAS & HEC-GeoRAS software
>>>> that is integrated with ArcGIS does this correctly.
>>> Well, that was just to showcase possibilities and then you come with a
>>> class on hidrology!!
>>> Thanks!
>>> I think it should be easy to add a slope to that flood surface, but
>>> that would be still incorrect.
>>> The solution would be to implement a flood modelling routine, but
>>> then, this is the beauty of free software! However, with all my
>>> excitement about all this, I am not the person to implement it... I'm
>>> still lacking some work on the localization of GRASS....
>>> I think I speak for the whole community when I say we are glad to see
>>> GRASS being used is such hi-profile tasks.
>> Thomas E Adams
>> National Weather Service
>> Ohio River Forecast Center
>> 1901 South State Route 134
>> Wilmington, OH 45177
>> EMAIL: thomas.adams at noaa.gov
>> VOICE: 937-383-0528
>> FAX: 937-383-0033
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
