[GRASSLIST:1075] Re: [GRASS-user] Trento3D screenshots redone
ivan marchesini
marchesini at unipg.it
Sat May 20 10:00:05 EDT 2006
Dear all...
I have done, in the past, an application of flooding inundation using
HEC-RAS and GRASS...
it was quite simple...
I have performed the simulation inside HEC-RAS and then I have put the
water level surface obtained at each river cross-section into GRASS
(simply drawing a line and adding the water level surface as an
attribute)
then v.surf.rst with correct tension values and I have obtained the
simulated water surface!!!
then r.mapcalc with the DEM to obtain the water level over the ground!!!
what about r.hydro.casc2d??? it was a module of grass5.4
I remember it was able to simulate flood-routing!!
the problem is it wasn't able to simulate bridge, culvert, ecc...
it would be nice if someone could improve it!!! :-)
I'm not sufficiently experienced!!
bye
Ivan
Il giorno ven, 19/05/2006 alle 09.49 -0400, Thomas Adams ha scritto:
> . Actually, the modeling would
> be done outside of GRASS and then have the appropriate water surface
> elevation data imported into GRASS to show the inundated areas. The
> hydraulic modeling *could* be done withing GRASS, but a better first
> step probably would be to do the modeling outside of GRASS and then
> import the data. An additional advantage to this is that there are
> many
> hydraulic models and one may have a preference as to which to use or,
> not be restricted to a particular model, thereby retaining more
> flexibility.
> Tom
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
jabber: geoivan73 at jabber.org
