[GRASS-user] Geographic Mean
Hamish
hamish_nospam at yahoo.com
Wed May 24 03:10:00 EDT 2006
> > Is the centroid of the hull equivalent to the centre of gravity of
> > all the points or is it the area centroid of the hull? Are these
> > the same?
> To my (admitably limited) understanding the definition of centroid is
> that it lies in the centre of gravity of an area. If I'm wrong, please
> correct me.
I would not make that assumption. e.g., where to put the centroid in a
2D toroid?
see Vect_get_point_in_area() in lib/vector/Vlib/poly.c
\fn int Vect_get_point_in_area ( struct Map_info *Map, int area, double
*X, double *Y)
\brief get point inside area and outside all islands
Take a line and intersect it with the polygon and any islands.
sort the list of X values from these intersections. This will
be a list of segments alternating IN/OUT/IN/OUT of the polygon.
Pick the largest IN segment and take the midpoint.
\return 0 on success, -1 on error
\param Map_info structure, area number, x, y
Then look in Vect_get_point_in_poly_isl() (same file)
Hamish
