[GRASS-user] nviz invalid pointer
Ian Allan
iallan at geocode.com.au
Sat May 27 08:16:00 EDT 2006
Hi
I've installed the grass6.0.2 binary onto a box using fedora core 5. I
upgraded from core 3 in the hope that NVIZ might start working. After
some time I got grass working after creating links relating to libssl
and mysqlclient. The final problem relates to nviz. I had better
success than under core 3 after i created links to libtcl & libtk.
However...
* In 6.0.2 the initial dialog box appears. After entering a DEM to
display and depressing "run", a small information box flashes,
followed by a flash of another larger box. Other than the initial
dialog box, no other NVIZ boxes stay on screen
* In 6.0.0 a similar thing happens, but it happens slower and is
accompanied by an error message that reads something along the
lines of...
o *** glibc detected *** NVIZ: munmap_chunk(): invalid
pointer: 0x097fed78: ...then follows a multi page dump
I tried downloading the latest src code & compiling it, however i am
very new to the linux environment and I had little success. I've been
working on this all yesterday and today, and have finally admitted
defeat. I would be grateful if someone could offer some help.
Many thanks
Ian
Ian Allan
Director Geocode Mapping and Analysis P/L
PO Box 2072
Edithvale VIC 3196
Ph: + 61 3 9773 1232 Fax: + 61 3 9773 1232
Mob: 0429 941 527
Email: iallan at geocode.com.au
Web: www.geocode.com.au
