[GRASS-user] vector maps - help needed - part 2
Maciek Sieczka
werchowyna at epf.pl
Tue May 30 16:39:38 EDT 2006
On Tue, 30 May 2006 22:10:42 +0200
Wolfgang <wollez at gmx.net> wrote:
> Hi all,
> sorry, but I still don't understand the vector/database handling of
> grass completely. At the moment I use dbf files, but this seems not
> to be very flexible. It seems also that not all vector data is stored
> in the dbf files.
Only attributes of vector features (point,line,centroid etc.) are
stored in the table (no matter what DB backend in Grass).
Note that a feature to have an entry in the table has got to have a
category first (see v.category).
> When I import for example a shapefile into grass,
> are all nodes of the lines imported to dbf?
No. One line is one, whole vector feature. If you need each node to have
separate table entry, use v.to.points -v, then v.to.db.
> I think no because I have
> an other folder on my computer which is called "vector" but what are
> the files "cidx,coor,dvln,head,hist,topo"?
> As you can see, I'm really confused, what this database stuff is for
> when all data is still stored somewhere else.
> I hope that somebody can help me and explain me the idea of
> vector/database handling.
v.in.ogr, as well as many other Grass modules that output a new vector
layer, will setup categories for features and upload them into a key
"CAT" column (it could be any other name though, see v.db.connect)
along with their attributes respectively.
Read your grass-6.1.cvs/docs/html/vectorintro.html too.
I hope it helps.
Best,
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
