[GRASS-user] [GRASSLIST:1089] Re: GRASS on Win98. Out of
environment space. GRASS Monitor not opening
David Finlayson
david.p.finlayson at gmail.com
Wed May 31 22:38:52 EDT 2006
Assuming that your machine is vintage windows 98, and you really want
GRASS to work on your current hardware. You might try installing a
light-weight GNU/Linux distribution and try GRASS that way.
I've read good things about DSL and XUbuntu (Google for these). Both
are designed to run in low-specification machines.
David
On 5/31/06, Jachym Cepicky <jachym.cepicky at centrum.cz> wrote:
> AFAIK GRASS can run only or Windows NT+ (2000, XP, 2003)
> Jachym
> On Tue, May 30, 2006 at 09:21:51PM -0700, Rochelle MIranda wrote:
> > Hello GRASS users
> > I have recently installed GRASS6 on win 98 systems using the
> > cygwin environment by creating a CD from iso file. It works fine on all systems.
> > however on one of the system it doesnt work fine.
> > i get the following error
> > "Out of environment space"
> > Also all the GRASS commands works fine.
> > But d.mon doesnt open up a monitor.
> > It opens the monitor only for a split second
> > and then the monitor closes.
> > Kindly help
> > I read archives to find the following
> > - Click on the MS-DOS prompt icon to get a shell window.
> > - Click on the fifth button from the left--the one that has a
> > "Properties"
> > tool tip when you hover over it with the mouse.
> > - Click on the "Memory" tab.
> > - In "Initial Environment", change the selection from "Auto"
> > to "4096" - Click "Ok".
> > - You'll get a warning dialog "The changes made to memory setting(s)
> > will not take effect until you restart the program". Click "Ok" to dismiss that dialog.
> > - Close the shell window.
> > - Click on the MS-DOS prompt icon again to get a new shell window. Run
> > BlueJ from that window.
> > - From now on, all new shell windows will have the increased environment
> > space.
> > Pls send any suggestions to make my GRASS monitor open
> > and also to remove the out of environment space error
> > Rochelle
> > Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
> e-mail: cepicky at gdf-hannover.de
> URL: http://gdf-hannover.de
> Tel.: +49 511-39088507
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (GNU/Linux)
> iD8DBQFEfUkjyKt0uAjU4I8RAuz/AJwLuIlGoE93QK2WYERIgB50uW7gTwCgr+q6
> PWor0FKt6D1U1P8t/pRsVCA=
> =JhjA
> -----END PGP SIGNATURE-----
David Finlayson
