[GRASS-user] eliminate some lines
    Moritz Lennert
    mlennert at club.worldonline.be
    Thu Nov  2 09:06:22 EST 2006
temiz wrote:
> Moritz Lennert wrote:
>> temiz wrote:
>>> /*hello
>>> I  couldn't do with v.clean what I wanted to do.
>>> I want to eliminate all lines whose their langth are under 20 m.
>>> what is the solution ?
>> not tested:
>> v.to.db map=Original option=length type=line col=linelength units=me
>> v.extract input=Original output=Original20 where="linelength>20"
>> Moritz
> thank you Moritz and Markus
> I solved this problem ( grass is really capable).
> When I looked at v.to.db, I thought whether I could calculate
> the "length of a polygon" as well.
Depends on the polygon. If it defined as a boundary, then try setting
type=boundary and option=length
If it is an area then type=area and option=perimeter
Moritz
