[GRASS-user] grass62/grass63 - broken html
Helmut Kudrnovsky
hellik at web.de
Sun Nov 5 13:10:46 EST 2006
hi michele,
i didn't enable odbc and mysql in the "./configure" step. this is maybe the reason?
if yes, it would be nice to have this html-links working, because the file "databaseintro.html" (with a lot of general things about db-management in grass) links to them and maybe someone who has not installed all db-drivers (like me) is interested also in this driver-help-pages i.e. for comparing the db-possibilities.
maybe i can help to fix this....
regards
helli
-----Ursprüngliche Nachricht-----
Von: michele.rocc at libero.it
Gesendet: 05.11.06 15:39:25
An: grassuser at grass.itc.it
Betreff: Re: [GRASS-user] grass62/grass63 - broken html
On Sunday 05 November 2006 14:36, Helmut Kudrnovsky wrote:
(HK)> hi again,
(HK)>
(HK)> i'looked a little bit more into the broken html-links. i've compiled
(HK)> from cvs-snapshot 2006-11-04 for grass62 and grass63. (HK)>
(HK)> in the grass62 cvs-snaphot 2006-11-04
(HK)> /usr/local/grass-6.2.1cvs/docs/html/grass-odbc.html existiert
(HK)>nicht.“
(HK)> (file not existing) (HK)>
(HK)> file:///usr/local/grass-6.2.1cvs/docs/html/grass-mysql.html ist
(HK)>folgender
(HK)> Fehler aufgetreten: (HK)> Die Datei oder der Ordner
(HK)> /usr/local/grass-6.2.1cvs/docs/html/grass-mysql.html existiert
(HK)>nicht.“
(HK)> /usr/local/grass-6.2.1cvs/docs/html/grass-mesql.html existiert
(HK)>nicht.“
did you enabled odbc and mysql in the "./configure step"?
Michele
_______________________________________________________________________
Viren-Scan für Ihren PC! Jetzt für jeden. Sofort, online und kostenlos.
Gleich testen! http://www.pc-sicherheit.web.de/freescan/?mc=022222
