[GRASS-user] How to JOIN a table to vector layer using MySQL
Moritz Lennert mlennert at club.worldonline.be
Thu Nov 9 08:58:55 EST 2006
Raffaele Morelli wrote:
> 2006/11/9, Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>:
>       > The solution would be to work with views.
>      > Grass sees views, connects to views and this is wonderful, but...
>     more
>      > it would be if it could handle them correctly. I tried to link to
>     views
>      > but quering on the attributes doesn't work correctly.
>     I use views successfully quite often with the postgres driver. Could you
>     be more specific about what does not work for you ?
>     Moritz
> With grass6.0 on a debian testing I connect succesfully to views.
> The problem arise when trying to query the layer connected to the view,
> it doesn't display (e.g. label) fields stored in the view or retrieve
> any information from there.
> It seems just like "Layer for labels" and "Layer for query" text box in
> the Gis Manager doesn't work properly with views, sometimes they simply
> ignore my SQL statements or retrieve incorrect values.
This might be an issue with layers, not with your view.
How do you use the layers ? Layers can be quite complex to understand
and there has been much discussion on them.
See here for a very short intro
http://www.grass.itc.it/grass63/manuals/html63_user/vectorintro.html
(section attribute management)
Have you tried connecting to a view without changing layers, i.e.:
- take a map MyMap for which you have a table MapTable in your database
- create a view with "create view NewView as select * from MapTable"
- connect your map to this view with 'v.db.connect -o map=MyMap
table=NewView key=KeyCol'
Do you have problems showing labels or querying the map ?
Moritz
