[GRASS-user] the performance of displaying vector attributes
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Nov 10 11:39:28 EST 2006
When storing attribute data in MySQL I have found creating an index on
relevant columns had made a large difference.
Cheers,
Dylan
On 11/10/06, Zbigniew Perski <perski at us.edu.pl> wrote:
> Hi,
> I am facing now with following problem:
> I have a large databases of points (more 30 000). I would like to
> visualize them in colors according to different attributes using
> d.vect.thematc and also store rgb information in the GRASSRGB column. I
> noticed that both methods are incredibly slow. It is very frustrating
> since you have to zoom and wait ages for refreshing the monitor. My
> database is stored using db engine. I would like to ask you if storing
> the point database using different engine like postgresql or mysql will
> have any impact on the performance in displaying the GRASSRGB column?
> I did not tested it yet but I am would like to know if it have any sense
> to spent some time on such try?
> Is there any other methods to speed-up the display performance in my
> case? I would like to add that I checked point displaying on various
> hardware combinations and I did not noticed any significant difference.
> It is always very slow.
> Thanks a lot
> Zbigniew
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
