[GRASS-user] Problems with v.outlier and v.lidar.edgedetection
Michael Perdue
michael_perdue at yahoo.ca
Sun Nov 12 23:45:38 EST 2006
Hi Roberto,
Thanks for the info. I'm still pretty new to macintosh and so far
haven't had much luck (read lazy) at setting up the environment for
building binaries myself. I did run it with the qgis option however,
and although it didn't complain about a "bus error", it did shut down
with the same error reported by v.lidar.edgedetection;
>> DBMI-DBF driver error:
>> Table 'Auxiliar_edge_table' doesn't exist.
>> Error in db_execute_immediate()
>> ERROR: Impossible to write in the database
So, it seems that what ever is causing the error is specific to mac
and may be common to all the v.lidar.* programs. I have a linux
workstation in the office and I did a cvs update earlier today. The
binaries were building when I left so in the morning I'll run
everything through it and then move the files over to my mac and see
if the issue also affects v.lidar.* and v.surf.bspline. I'll let you
know what I find out. Let me know if there is anything I can do to be
of assistance.
Cheers and thanks again!
Mike
On 10-Nov-06, at 3:43 AM, Roberto Antolin wrote:
> Hi Michael and all,
> I'm the v.outlier and v.lidar.* developer. First of all, I'm very
> sorry for these bugs.
> I knew the v.outlier bug from long time ago but I didn't fix it and
> I forgot it. I've just fixed and now I will send it to the CVS. So,
> you will able to download the new version from there. A dirty
> solution is:
> ~ > v.outlier input=pslc2k_sub2 output=clean outlier=outlier
> qgis=clean_qgis
> This should run ok.
> So, if you don't need the qgis output you can remove it. The qgis
> output vector parameter was done to allow the visualization of the
> point's color as a function of its height within qgis. But this
> approach needs that the topology is built and the height is
> considered as a category. However, the standard output ("outlier="
> and "outlier=") are done without topology and with the height as
> the z-coord in a 3d-vector.
> The v.lidar.edgedetection bug is a new one. I'll try to fix it as
> soon as possible. Another thing, I advice you about this module. It
> doesn't run with dbf driver and db because the sql setences used
> are not allow for them. But this is not the error in this case.
> I'm sorry very much,
> Roberto.
> Michael Perdue ha scritto:
>> Good Morning,
>> I've been playing with some tools for working with lidar data sets
>> and I've encountered two problems. First, when I try to run
>> v.outlier the module immediately exits with "Bus error" warning.
>> GRASS 6.2.0 (Mudflats):~ > v.outlier input=pslc2k_sub2
>> Bus error
>> Second, in my attempts to classify the point clouds
>> v.lidar.edgedetection runs for a while and then exits with the
>> following error;
>> GRASS 6.2.0 (Mudflats):~ > v.lidar.edgedetection input=Gldcrk_sub2
>> output=edge
>> I'm running GRASS on an intel mac (OSX 10.4.8). Does anyone have
>> any insight into either of these issues?
>> Cheers,
>> Mike
>> __________________________________________________
>> Do You Yahoo!?
>> Tired of spam? Yahoo! Mail has the best spam protection around
>> http://mail.yahoo.com
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> Roberto Antolín Sánchez
> Politecnico di Milano – Polo Regionale di Como
> (Laboratorio di Geomatica V2.8)
> Via Valleggio, 11 – 22100 Como, Italy
> tel: +39 031 332 7533 || fax: +39 031 332 7519 email:
> roberto.antolin at polimi.it
Do You Yahoo!?
