[GRASS-user] file size limit exceeded
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Mon Nov 13 06:23:26 EST 2006
Hello,
I tried to import a 500 MB DEM using GRASS 6.2 (Debian rep):
#1
r.in.gdal -o -k -e
input=/data2/raster/dem/srtm90_africa_continental_JF/SRTM90_WA_v3/SRTM90_WA_v3/hdr.adf
output=test
Over-riding projection check.
Proceeding with import...
WARNING: map [test] - unable to write row 14319
File size limit exceeded
[Raster MASK present]
#2
did it without -e and previously zoomed into the mapset and set the region to
fit this extend using gis.m functionality (not CLI)
same error message
#3
I found related error messages in the ML hence I installed grass62 and 63 with
LFS but I have some problems compiling with gdal support (another e-mail on
gda-dev)
any idea how I can solve this file size limit problem while not yet being able
to compile 62/63?
regards, Martin
