[GRASS-user] r.reclass probs with negative values
Mon Nov 13 10:08:34 EST 2006
Malte Halbey-Martin wrote:
> Hi Grass Users out there,
> certainly something total easy, but is there a way to reclassify
> negative values with r.reclass?
> fp: Data range is -0.2180119007825851440429688 to
> 0.1608885973691940307617188
>  > -0.2180119007825851440429688 thru 0.001 = 1 label
> -0.718012 rounded up to 0
> 0.501000 rounded up to 0
> Does r.reclass only work with integer or positive values? I couldn't
> find anything about that in the manual.
Only integer maps can be reclassed.
