[GRASS-user] the performance of displaying vector attributes
- with MySQL no difference!!
Zbigniew Perski
perski at us.edu.pl
Tue Nov 14 04:57:08 EST 2006
On Mon, 2006-11-13 at 19:52 +0100, Jarek Jasiewicz wrote:
> > Hi again,
> > the problem of my database is that I don't see any way to optimize it.
> > Imagine if you have 20 thousands of xyz points and want just to
> > visualize them in different colors (dem-like color scale). Each point
> > has its unique x,y,z values...
> > I tried to assign indexes for my "z" column using:
> > ALTER TABLE my_points ADD INDEX(z_ccordinate);
> > And I don't see any difference in performance with e.g. v.univar.sh
> > So maybe I am doing something wrong?
> If I understood well from the previous post threre is a RGB column it is
> indexed? how much categories of rgb colors you have. If you have as many
> categories as values this is the problem. In grass, graphical engine
> must assing color and render every pixel individualy
Right I have tried both: to index my "z" column and then grassrgb as
well. There are 30 categories and I guess it would speed up things.
Maybe I was wrong with indexing?
Thanks
Zbigniew
