[GRASS-user] Problem in display after v.overlay command
Tue Nov 14 20:01:14 EST 2006
hemant moharir wrote:
>     I use v.overlay command for attaching Shape
> file.But when v.overlay complete.I try to display
> resulted .shp file.Monitor displays blank.
>     What is the problem?
try "v.info mapname" to check if there are any features in the new map.
grass can import/export the ESRI .shp file format, but doesn't use
them internally. (unless you use v.external)
Hamish
