[GRASS-user] nulls left by r.surf.nnbathy
Maciej Sieczka
tutey at o2.pl
Wed Nov 15 12:18:50 EST 2006
Maciej Sieczka wrote:
> Try using the attached earlier version of r.surf.nnbathy (1.2).
Now attaching it. Really.
Maciek
#!/bin/bash
# MODULE: r.surf.nnbathy
# AUTHOR(S): Maciej Sieczka, sieczka at biol.uni.wroc.pl
# Intitute of Plant Biology, Wroclaw University, Poland
# PURPOSE: Interpolate raster surface using the "nnbathy" natural
# neighbor interpolation program.
# VERSION: 1.2, developed over Grass 6.1 CVS 2006.05.18
# COPYRIGHT: (c) 2006 Maciej Sieczka
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
### NOTES:
### 1. Requires nnbathy executable, download from
### http://www.marine.csiro.au/~sakov/. At the time of writing the script
### 1.57 was the most recent version.
### 2. When creating the input elevation raster, make sure it's extents cover
### your whole region of interest, the no-data cells are NULL, and the
### resolution is correct. As most Grass raster modules this one is region
### sensitive too.
#%Module
#% description: Interpolate raster using the nnbathy natural neighbor interpolation program.
#%END
#%option
#% key: input
#% type: string
#% gisprompt: old,cell,raster
#% description: The raster to interpolate, with NULL assigned to no-data cells
#% required : yes
#%END
#%option
#% key: output
#% gisprompt: new,cell,raster
#% type: string
#% description: Name of the output raster
#% required : yes
#%END
# called from Grass?
if test "$GISBASE" = ""; then
echo "ERROR: You must be in GRASS GIS to run this program." >&2
exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
# check if we have awk
if [ ! -x "`which awk`" ] ; then
echo "ERROR: awk required, please install awk or gawk first." 1>&2
exit 1
fi
# check if we have nnbathy
if [ ! -x "`which nnbathy`" ] ; then
echo "ERROR: nnbathy required, please download from http://www.marine.csiro.au/~sakov/ and put the nnbathy executable in your $PATH." 1>&2
exit 1
fi
# set environment so that awk works properly in all languages
unset LC_ALL
export LC_NUMERIC=C
# set up temporary files
TMP="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
echo "ERROR: Unable to create temporary files." 1>&2
exit 1
fi
PROG=`basename $0`
# cleanup temp files
cleanup()
\rm -f $TMP $TMP.${PROG}.region $TMP.${PROG}.canvas_xyz $TMP $TMP.${PROG}.input_xyz $TMP.${PROG}.output_xyz $TMP.${PROG}.output_grd
# what to do in case of user break:
exitprocedure()
echo "User break!"
cleanup
exit 1
# shell check for user break (signal list: trap -l)
trap "exitprocedure" 2 3 15
INPUT="$GIS_OPT_INPUT"
OUTPUT="$GIS_OPT_OUTPUT"
### DO IT ###
# extract the current region settings
g.region -g > $TMP.${PROG}.region
# set variables
north=`awk 'BEGIN {FS="="} (NR==1) {print $2}' $TMP.${PROG}.region`
south=`awk 'BEGIN {FS="="} (NR==2) {print $2}' $TMP.${PROG}.region`
west=`awk 'BEGIN {FS="="} (NR==3) {print $2}' $TMP.${PROG}.region`
east=`awk 'BEGIN {FS="="} (NR==4) {print $2}' $TMP.${PROG}.region`
rows=`awk 'BEGIN {FS="="} (NR==7) {print $2}' $TMP.${PROG}.region`
cols=`awk 'BEGIN {FS="="} (NR==8) {print $2}' $TMP.${PROG}.region`
null=nan
type=double
# spit out non-null (-n) raster coords + values to be interpolated
r.stats -1gn input="${INPUT}" > $TMP.${PROG}.input_xyz
# spit out the "canvas" coords for nnbathy to interpolate in
r.stats -1g input="${INPUT}" | awk '{print $1" "$2}' > $TMP.${PROG}.canvas_xyz
# interpolate
echo
echo "nnbathy in action. May take some time. Please stand by." 1>&2
echo
nnbathy -i $TMP.${PROG}.input_xyz -o $TMP.${PROG}.canvas_xyz > $TMP.${PROG}.output_xyz
# convert the X,Y,Z nnbathy output into a Grass ASCII grid, then import with r.in.ascii:
# 1 create header
cat << EOF > "$TMP.${PROG}.output_grd"
north: $north
south: $south
east: $east
west: $west
rows: $rows
cols: $cols
null: $null
type: $type
EOF
# 2 do the conversion
echo "Converting nnbathy output to Grass raster. Please stand by." 1>&2
echo
awk -v cols="$cols" '
BEGIN {col_cur=1; ORS=" "}
if (col_cur==cols) {ORS="\n"; col_cur=0; print $3; ORS=" "}
else {print $3}
col_cur++
}' $TMP.${PROG}.output_xyz >> "$TMP.${PROG}.output_grd"
#### TESTING ###
#cp $TMP.${PROG}.output_grd dem.asc
# 3 import
r.in.ascii input=$TMP.${PROG}.output_grd output=${OUTPUT}
### ALL DONE ###
echo
echo "Done." 1>&2
echo
cleanup
