[GRASS-user] grass62-cvs-serversnapshot 2006/11/18: compiling error
Helmut Kudrnovsky
hellik at web.de
Sun Nov 19 09:52:15 EST 2006
hi,
i've downloaded yesterday the cvs-snapshot: grass-6.2.cvs_src_snapshot_2006_11_18
configuration with following options seems to be ok:
./configure --with-cxx --with-postgres --with-postgres-libs=/usr/include/pgsql/libpq --with-postgres-includes=/usr/include/pgsql/ --with-sqlite --with-freetype --with-freetype-includes=/usr/include/freetype2 --with-glw --with-proj-share=/usr/share/proj
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /home/helli/tempinstall/grass62/grass-6.2.cvs_src_snapshot_2006_11_18
Build directory: /home/helli/tempinstall/grass62/grass-6.2.cvs_src_snapshot_2006_11_18
Installation directory: /usr/local/grass-6.2.1cvs
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
FORTRAN compiler:
Building shared libraries: yes
64bit support: no
OpenGL platform: X11
NVIZ: yes
BLAS support: no
C++ support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GLw support: yes
JPEG support: yes
LAPACK support: no
Large File Support (LFS): no
Motif support: no
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: yes
Python support: no
Readline support: no
SQLite support: yes
Tcl/Tk support: yes
TIFF support: yes
X11 support: yes
after make:
Following modules are missing the 'description.html' file in src code:
GRASS GIS compilation log
Started compilation: So Nov 19 14:01:05 CET 2006
Errors in:
/home/helli/tempinstall/grass62/grass-6.2.cvs_src_snapshot_2006_11_18/raster/r.surf.fractal
Finished compilation: So Nov 19 14:10:20 CET 2006
(In case of errors please change into the directory with error and run 'make')
make: *** [default] Fehler 1
make in the error-directory with the following messages:
helli at linux-ni8p:~/tempinstall/grass62/grass-6.2.cvs_src_snapshot_2006_11_18/raster/r.surf.fractal>
make
gcc -I/home/helli/tempinstall/grass62/grass-6.2.cvs_src_snapshot_2006_11_18/dist.i686-pc-linux-gnu/include -g -O2 -DPACKAGE=\""grassmods"\" -I/home/helli/tempinstall/grass62/grass-6.2.cvs_src_snapshot_2006_11_18/dist.i686-pc-linux-gnu/include \
-o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In Funktion »main«:
main.c:34: Fehler: »EXIT_SUCCESS« undeclared (first use in this function)
main.c:34: Fehler: (Each undeclared identifier is reported only once
main.c:34: Fehler: for each function it appears in.)
make: *** [OBJ.i686-pc-linux-gnu/main.o] Fehler 1
compiling with the same options and grass63-cvs-snapshot from yesterday was ok.
regards
helli
-+o++o++o++o++o++o++o++o+-
helmut kudrnovsky
internet: www.alectoria.at
______________________________________________________________________
XXL-Speicher, PC-Virenschutz, Spartarife & mehr: Nur im WEB.DE Club!
Jetzt gratis testen! http://freemail.web.de/home/landingpad/?mc=021130
