H.S.Rai wrote: > <snip> > > GRASS read Autocad files? > > You can save drawing in dxf format from AutoCAD, and then v.in.dxf in > GRASS will do the work. or import DWG format with v.in.dwg if you are willing to abide by OpenDWG's terms and compile it yourself. Hamish
