Jason Horn wrote: > How would you determine if a point is contained within a polygon in > GRASS? The point and polygon can be in separate vector files, or in > the same vector file - doesn't mater to me. v.overlay or v.select. Hamish ps- the mailing list has moved from baylor to itc.
