[GRASS-user] calculate pixel areas with starspan
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Nov 20 13:12:36 EST 2006
On Sunday 19 November 2006 21:53, maning sambale wrote:
> Hi,
> I have grass rasters and I want to calculate raster classes based on
> the attributes of a shapefile. I'm experimenting with starspan and so
> far its extremely fast than:
> v.in.ogr #to export shapefile
> v.build and v.digit #to check for topology problems
> v.to.rast
> r.report
> But, how can I get area coverage (in percent and hectares) from a
> given raster class in a polygon?
> Any ideas?
> Cheers,
> Maning
Hi Manning,
How are you invoking starspan, and what exactly do you mean by "an area
coverage" ?
You might check out the "mini-raster" options in starspan:
--mini_rasters <prefix>
--mini_raster_strip <filename>
I believe that these will extract "mini" rasters for each vector feature. Be
sure to read the documentation however.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
