[GRASS-user] AutoCAD import [was ]2nd edition book?
Stefano Costa steko at iosa.it
Tue Nov 21 04:17:36 EST 2006
Il giorno mar, 21/11/2006 alle 11.52 +1300, Hamish ha scritto:
> v.in.dwg is not, due to OpenDWG license restrictions. You will need to
> get the OpenDWG library and compile the module yourself if you want
> that.
You could also try OrbisCAD http://orbiscad.sf.net which does import DWG
files and can output Shapefiles as well to be used in GRASS.
It is based on the jdwg library (not very clear to me its licensing btw)
Best regards,
Stefano
Stefano Costa
http://www.iosa.it Open Archaeology
http://list.iosa.it International Mailing List
Jabber: steko at jabber.linux.it
