[GRASS-user] v.to.rast on 3D polygons?
William Kyngesburye
woklist at kyngchaos.com
Tue Nov 21 17:48:52 EST 2006
A bit stumped on this:
I imported a 3D polygon shapefile with v.in.ogr and the 3D (-z)
option to generate a 3D area vector. Without the 3D option, the
polygon heights are dropped altogether, without adding them to the
attribute table.
I now want to make a raster with area fills corresponding to the
elevation (height) of the 3D polygons. According to the v.to.rast
docs, the use=z option only works for points and lines, and indeed
all that gives me is single cells at the centroids.
As a workaround I thought I'd put the elevation into the db table
with v.to.db, but there is no z option, just area and perimeter.
Any ideas how to get the 3D z value into a raster fill?
Is it possible to add a z option for v.to.rast (for areas) and/or
v.to.db?
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
