[GRASS-user] v.to.rast on 3D polygons?
William Kyngesburye woklist at kyngchaos.com
Wed Nov 22 18:09:49 EST 2006
On Nov 22, 2006, at 4:02 PM, Maciej Sieczka wrote:
> William Kyngesburye wrote:
> <snip>
>> I thought I'd put the elevation into the db table with
>> v.to.db, but there is no z option, just area and perimeter.
>> Any ideas how to get the 3D z value into a raster fill?
>> Is it possible to add a z option for v.to.rast (for areas) and/or
>> v.to.db?
> There is one already in v.to.db - "coor: point coordinates, X,Y or
> X,Y,Z". Does this work with geometries other than point I don't know;
> can you verify?
Pretty obvious.  My brain gets on a track (looking for Z by itself)
and misses something so obvious.  That should work for the workaround
method, but it would be nice to have a direct access to the Z value
in v.to.rast.
Seems to work, mostly.  One of my polygons didn't get filled, but has
a single cell at the centroid.  I looked with v.digit, and the
topology is correct.  The boundary isn't labelled.
It looks like it's because the raster grid alignment is off a half a
cell from the resolution.  When I aligned the region to the region's
resolution, all polygons got filled.
Where this is coming from: I have the SRTM DEMs v2 all imported.
They are cell-centered, at 3" cell size, so their regions are 1.5"
off from 3".  ie, a 1 degree tile's region might be:
north:      20:00:01.5N
south:      18:59:58.5N
west:       156:00:01.5W
east:       154:59:58.5W
nsres:      0:00:03
ewres:      0:00:03
rows:       1201
cols:       1201
Then I import the SRTMv2 coast file for the same tile.  Those are
annoyingly aligned to the cell edges:
north:      20N
south:      19N
west:       156W
east:       155W
nsres:      0:00:03
ewres:      0:00:03
rows:       1200
cols:       1200
But I want a grid, with elevations for the lakes that are in these
coast files though that's not critical, aligned to the DEM's grid, so
I can *cleanly* mask off the ocean areas.  With the mask grid a half
cell off from the DEM grid, resampling will get in the way of a clean
mask.
Though, I guess since there is so much noise in the SRTM data, I
could just resample the DEMs to align them to the grid without losing
too much.  That would reduce some other headaches coming from the
alignment.  hmmmm....
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do
if you ARE a maniacally depressed robot?  No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
