[GRASS-user] SQL syntax in DBF vs SQLite for substring matching
Hamish
hamish_nospam at yahoo.com
Wed Nov 22 21:38:59 EST 2006
this works with DBF but fails with SQLite:
where="str_2 ~ 'Wed'"
DBMI-SQLite driver error:
Error in sqlite3_prepare():SELECT cat FROM icebergs WHERE str_2 ~ 'Wed'
near "~": syntax error
with SQLite it has to be:
where="str_2 LIKE '%Wed%'"
is "~" non-standard SQL? is there other syntax which can't be trusted
to work the same? (not including DBF limitations)
see
http://grass.ibiblio.org/grass63/manuals/html63_user/grass-dbf.html
thanks,
Hamish
