[GRASS-user] problems building grass 6.3
Thu Nov 23 16:20:50 EST 2006
Seb wrote:
> Until recently I've been successful building grass 6.3 from CVS by
> first configuring it using:
(Debian, right?)
> | export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
> | cvs login
this is only needed once.
> which produces the following when called:
> However, I am currently getting many errors during build, and I've
> stored the results with 'make 2>&1 | tee make_log.txt':
> | --- Following modules are missing the 'description.html' file in src
> | code:
> | r.li.patchnumber
> | r.li.shape
> | r.watershed.ram
> | r.watershed.seg
r.watershed.* don't need man pages, that they show up here is an error in
a Makefile somewhere.
> | Errors in:
> | /usr/local/src/grass-cvs/lib/proj
> Further up the log, I can see where these errors come from, e.g.:
> | make[2]: ***
> | [/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/lib/libgras
> | s_gproj.6.3.cvs.so] Error 1 make[2]: Leaving directory
> | `/usr/local/src/grass-cvs/lib/proj' rowio
> | Errors in:
> | /usr/local/src/grass-cvs/lib/vector/Vlib
you need to show more of the error report. (we see the where but not the why)
> AFAICT nothing has changed in my system since last time this procedure
> worked.  I would be grateful for any advice on how to properly build
> this grass version.
I had a similar problem the other day with Debian ("missing -lgeos"),
solution was to install the libgeos-dev package. I don't know what change
in GRASS made that GDAL prerequisite suddenly a requirement for building
GRASS.
Hamish
