[GRASS-user] Clarification on units used in r.sun
Hamish
hamish_nospam at yahoo.com
Wed Nov 29 01:59:06 EST 2006
Dylan Beaudette wrote:
> Hi everyone,
> Quick question on the units used for the ouput of r.sun in mode 2
> (daily sums):
> In the manual pages for r.sun, the following 'unit' is included in the
> description:
> The solar radiation maps for given day are computed integrating the
> relevant irradiance between sunrise and sunset times for given day.
> The user can set finer or coarser time step step used for all-day
> radiation calculations. A default value of step is 0.5 hour. Larger
> steps (e.g. 1.0-2.0) can speed-up calculations but produce less
> reliable results. The output units are in Wh per squared meter per
> given day [Wh/(m*m)/day].
> Is one to interpret this as "watt-hour per square meter per day" ?
> This would seem a little odd, as the the unit 'watt-hour' is not an SI
> unit. Hopefully I am reading this incorectly.
If you want SI, 1 Wh = 3600 watt-sec (joules)
> An alternative interpretation of these units (one which I hope to be
> the correct one):
> Wh.m-2.day-1 = "watts per square meter per day, as estimated at some
> fraction of an hour" ?
mode 1 is instantaneous flux
mode 2 is cumulative energy / area, summed for the day
ie watt-hours per square meter, summed over enitre day. The "dt"
timestep for the numerical intergration is set by the step= parameter
(default 30 minutes).
To convert to micro-moles (micro-Einsteins) you have to pick an energy
level (light wavelength) and convert using that. (moles of photo quanta)
Hamish
