[GRASS-user] Clarification on units used in r.sun
Glynn Clements
glynn at gclements.plus.com
Wed Nov 29 15:31:09 EST 2006
Dylan Beaudette wrote:
> Quick question on the units used for the ouput of r.sun in mode 2 (daily
> sums):
> In the manual pages for r.sun, the following 'unit' is included in the
> description:
> The solar radiation maps for given day are computed integrating the relevant
> irradiance between sunrise and sunset times for given day. The user can set
> finer or coarser time step step used for all-day radiation calculations. A
> default value of step is 0.5 hour. Larger steps (e.g. 1.0-2.0) can speed-up
> calculations but produce less reliable results. The output units are in Wh
> per squared meter per given day [Wh/(m*m)/day].
> Is one to interpret this as "watt-hour per square meter per day" ?
> This would seem a little odd, as the the unit 'watt-hour' is not an SI unit.
More odd (to me) is having (different) units of time in both the
numerator and denominator. I would have thought it more logical to
divide the result by 24 to give Watts per square metre [W/(m^2)].
