[GRASS-user] Re: raster MASKs;
was [GRASS-dev] interferring ovewrite flags
Michael Barton
michael.barton at asu.edu
Mon Oct 2 12:30:29 EDT 2006
OK. Thanks. It took a bit of re-reading this to get it all--and to connect
the dots with your initial post. I think the r.mask script does not have
these issues because it uses r.reclass (like the original GRASS 5 r.mask
did), but it is a good reason for caution when using r.mapcalc to create a
MASK. Just to make sure I've got it, could you check my comments below?
Thanks
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Mon, 2 Oct 2006 20:37:36 +1300
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grassuser at grass.itc.it>
> Subject: Re: raster MASKs; was [GRASS-dev] interferring ovewrite flags
> Michael Barton wrote:
>> Right. I understand, even if I didn't phrase it that way. Does this
>> happen for any r.mapcalc processing using the same procedures or just
>> ones in which MASK is the result? Also, is it always an "and" or can
>> you also get the effects of an "or"? Definitely a 'gotcha' to watch
>> out for. I'm concerned especially because we are doing a lot of
>> iterative r.mapcalc processing in scripts and this could be a problem.
> The MASK is generally applied when a row of input data is read from the
> disk.
> A module scan specifically ask to ignore the MASK, but the vast vast
> majority of raster modules process data by row (to save memory), and use
> G_get_raster_row() to do that.
> G_get_raster_row_nomask() is the non-masking version. Things that use it:
> display/d.rast.edit/mk_tmp_file.c
> imagery/i.rectify/perform.c
> imagery/i.ortho.photo/photo.rectify/perform.c
> raster/r.compress/main.c
> raster/r.le/r.le.patch/driver.c
> raster/r.le/r.le.patch/trace.c
> raster/r.le/r.le.pixel/cellclip.c
> raster/r.le/r.le.pixel/driver.c
> * raster/r.null/null.c
These commands do NOT respect a MASK ???
> So:
> r.mapcalc MASK='if(isnull(roads))'
> r.mapcalc MASK=fields
> d.rast elevation.dem # displays with holes
> r.mapcalc one=1 # full coverage once MASK is removed
> r.mapcalc two=elevation.dem # holes once MASK is removed
> g.remove MASK
> d.rast one
> d.rast two
r.mapcalc will respect a MASK ONLY if the formula to create a new map
includes an existing map (i.e., read from disk).
A new map created from a formula that does NOT include an existing map will
NOT respect a MASK, even though it may APPEAR to do so when you display it
using d.rast with a MASK in place--because d.rast DOES respect a MASK.
> the numeric mapcalc cmd hasn't read a map from the disk, so in fact it
> is a solid block. The "two" map has read, so in fact contains holes.
> If the "one" map is displayed with a MASK in place, it appears to have
> holes in it, but these are introduced when d.rast loads the map to
> display it.
> clear?
I think so.
...From earlier message
> "additive" in a processing sense, not mathematical. (still 0|NULL,1)
> for example: (spearfish)
MASK created with holes for roads
r.mapcalc reads map "fields", respecting MASK that leaves holes for roads,
and writes new MASK with fields but without roads.
d.rast respects new MASK that is limited to fields without roads.
> shows elevation where there is fields but no roads, as fields is read
> in with a mask in place.
