[GRASS-user] Linux prompt messed up
    Daniel Victoria
    daniel.victoria at gmail.com
    Thu Oct  5 13:17:07 EDT 2006
Thanks for the help Larry,
I think I found out what I did wrong. There was a .bashrc.save file in
the directory and I believe grass changed my bashrc and then it did
not change back. I restored the old bashrc.save and now everything is
back. Probably the old temporary files where not cleaned up correctly
Cheers
Daniel
On 10/5/06, Larry Prevett <prevettl at gmail.com> wrote:
> On 10/5/06, Daniel Victoria <daniel.victoria at gmail.com> wrote:
> > HI,
> > I compiled and installed Grass6.2RC1 and was using it normaly when the
> > conection from the windows terminal to the linux box where I run grass
> > shut off. Now, when I open the terminal in the linux box the bash
> > prompt is GRASS 6.2.0RC1 ():~ >
> > How can I make it go back to the way it was?
> > Should I delete some grass temp file?
> > Thanks
> > Daniel
>  to set the linux terminal prompt to [user at server_name directory]
>  put
>    PS1="[\u@\h \W]\\$ "
>  in /home/youraccount/.bashrc
>  and
>    source .bashrc
>    (or log out, log back in)
> see the man page for bashrc for the other prompt options
>  lp
