[GRASS-user] Large vector files
Jonathan Greenberg
jgreenberg at arc.nasa.gov
Thu Oct 5 14:37:25 EDT 2006
Hmm, I am using the binaries from
http://www.kyngchaos.com/software/unixport/grass/ --> assuming LFS was
enabled (I can always recompile if I need to), are there large file issues
with *vectors* I need to worry about? The raster LFS is fine, mind you --
I'm very happy with that. I'm just a bit fed up with ArcMap's 2gb
limitation on file sizes, and I'm wondering if GRASS has ESRI beat in vector
LFS along with the raster LFS...
--j
On 10/5/06 11:43 AM, "Dylan Beaudette" <dylan.beaudette at gmail.com> wrote:
> On Thursday 05 October 2006 11:13, Jonathan Greenberg wrote:
>> I wanted to get some feedback on how well GRASS works with very large
>> vector files (> 2gb) -- I have a 64 bit mac that I have grass running on
>> now, so I'm hoping the 64 bit memory system will work -- thoughts?
>> --j
> Hi Jonathan,
> did you enable large file support ?
> Cheers,
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
Office: 650-604-5896
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307 at hotmail.com
