[GRASS-user] Large vector files
    Jonathan Greenberg
    jgreenberg at arc.nasa.gov
    Thu Oct  5 15:51:21 EDT 2006
Case in point: I just got this error on a v.in.ascii import of a ~200mb csv
file with points:
G_realloc: out of memory (I have 4gb RAM and plenty of swap space, and the
program never hit that limit anyway).
I'm pretty sure this binary is *not* compiled for 64-bit macs, so I may
recompile GRASS myself...
Sorry, I meant > 4gb (these files are probably going to be up to 8gb in
size).
--j
On 10/5/06 12:33 PM, "gary" <lists at lazygranch.com> wrote:
> You can access about 4G with 32 bits, so 64 bits doesn't necessarily
> help. The big advantage to using a 64 bit CPU is the double precision
> math is much more efficient. This assumes you have compiled the program
> using 64 bit libraries.
> I use a 64 bit AMD 4.4Ghz dual core running suse 10.0
> Jonathan Greenberg wrote:
>> I wanted to get some feedback on how well GRASS works with very large vector
>> files (> 2gb) -- I have a 64 bit mac that I have grass running on now, so
>> I'm hoping the 64 bit memory system will work -- thoughts?
>> --j
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
Office: 650-604-5896
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307 at hotmail.com
