[GRASS-user] UTM concepts
Brent Wood
b.wood at niwa.co.nz
Sun Oct 8 21:53:58 EDT 2006
>> Hi,
>> I'm trying to learn GRASS a second time and find myself struggling again
>> with the basic issue of defining a region.
>> I have a series of data sources with varying projections and extents
>> covering the region I'm interested in. I would like to work on a UTM
>> projection with WGS84 datum for all analyses of this region, so would have
>> to reproject and clip the original data sources to this standard.
>> Since the region of interest covers several UTM zones, I don't understand
>> how I should define the region for this project. For instance, If I
>> choose the UTM zone corresponding to the center of the region I'm
>> interested in, how does one specify the limits of the region, considering
>> that the data will span several (4) UTM zones?
This addresses my main (pretty much only!) gripe about GRASS. I suggest
that projections, etc are simply metadata describing a dataset. As such,
being forced to change all my data to one predefined projection/datum is
a significant inconvenience, which has largely precluded my making any
real use of GRASS.
I get data & updates from various institutes/repositories around the
world, in a variety of projections. I want to use these data as they
are, without requiring two complete sets (the GRASS reprojected copy &
the original) which requires on the fly reprojection.
GMT, QGIS, PostGIS and increasingly, UMN mapserver (the FOSS GIS tools I
use most) all support on the fly reprojection, so my workspace can
pretty much seamlessly overlay data stored in NZTM, NZMG, mercator, UTM,
lat/long and polar coordinate systems & projections.
Is there any plan to make GRASS less restrictive in the way it deals
with data covering the same region but in different projections? (Or
have I missed something & it has already been done?)
I assume the entire GRASS codebase is oriented around the
mapset/predefined region/datum/projection and that any shift from this
model would be a huge undertaking, but am wondering if supporting on the
fly reprojection has been considered at all?
Thanks,
Brent Wood
