[GRASS-user] How to find whether one vector is contained by another
Wed Oct 11 19:14:30 EDT 2006
Patton, Eric wrote:
> A lot of time I get requests to find out what vector navigation
> tracklines fall within a certain region. This is easy to do by visual
> inspection (turning on and off vectors in gis.m) when the number of
> vectors is low, but becomes too much work for large numbers (i.e.,
> 200). What is the best way to find out if one vector is contained by
> another, without writing any output? All I need is a listing of vector
> names.
[v.select; ... ; g.remove]
Jeroen Wortel wrote:
> A nice addition to Grass would be vector selections that are kept in
> memory instead of written to an output file. Only the pointers to the
> geometry need to be kept in memory, no actual geometry. These
> selection could be used in other grass commands just like normal
> vector maps. This mechanism works for example in GenaMap (called
> active ID's) and is very powerful for scripting purposes and saves a
> lot of temporary files on disk. (This would mean however that vector
> indices should be kept in the vector files instead of created every
> time)that When doing a selection inside or a proximity in GenaMap, the
> number of selected features is returned.
there is a v.external "Memory" driver from OGR, but I'm not sure what
it does exactly.
in the GDAL source:  ogr/ogrsf_frmts/mem/
 * Project:  OpenGIS Simple Features Reference Implementation
 * Purpose:  Implements OGRMemDriver class.
but nothing I could find in:
http://gdal.org/ogr/ogr_formats.html
Hamish
