[GRASS-user] RE: [GRASS-dev] Can't create locations using EPSG codes
Patton, Eric
epatton at nrcan.gc.ca
Fri Oct 13 14:31:47 EDT 2006
Helena,
Thanks for hint. I tried your suggestions, but the error remains the same. I
managed to create the location using EPSG 2036 in Grass 6.1. I have no idea
why it worked there and not 6.3.
~ Eric.
-----Original Message-----
To: Patton, Eric
Sent: 10/13/2006 1:08 PM
Subject: Re: [GRASS-dev] Can't create locations using EPSG codes
On Oct 13, 2006, at 11:44 AM, Patton, Eric wrote:
> One thing that I just noticed is that my epsg file isn't in the
> standard
> location as the default path of /usr/local/share/proj/epsg given in
> the
> Grass startup screen. My epsg is in /usr/share/proj/epsg - but I
> specify
> this path to the startup window, so it should just get passed
> verbatim.
> Could that make any difference?
that may be the problem - I have similar problem when using the
projection definition
from a file - it cannot find it using the path I give it (I haven't
tried to start GRASS
from the same directory where the file is or the one that is default
- that may work),
Helena
> ~ Eric.
> From: grass-dev-bounces at grass.itc.it
> To: 'Maciej Sieczka '
> Cc: ''grassuser at grass.itc.it' '; ''grass-dev at grass.itc.it ' '
> Sent: 10/13/2006 11:37 AM
> Subject: RE: [GRASS-dev] Can't create locations using EPSG codes
> Maciek,
> Thanks for testing this. I wonder what could be causing the problem
> for
> me
> then? I'm at a complete loss to explain this. I'm using today's cvs. I
> have
> gdal 1.3.2 and the gdal-grass 1.3.1 plugin installed, it that makes
> any
> difference.
> ~ Eric.
> From: Maciej Sieczka
> To: Patton, Eric
> Cc: 'grassuser at grass.itc.it'; 'grass-dev at grass.itc.it '
> Sent: 10/13/2006 11:21 AM
> Patton, Eric wrote:
>> Trying to create a new location from the Grass intro screen, using
> EPSG code
>> 2036 (New Brunswick Double Stereographic)gives the following error:
>> child process exited abnormally
>> Can anyone reproduce this error for me? I'm using Ubuntu 6.06.
> On the same Ubuntu it works for me, uisng 6.3 CVS 2006-10-11. The
> location created is:
> GRASS 6.3.cvs (test2):~ > g.proj -p
> -PROJ_INFO-------------------------------------------------
> proj : sterea
> a : 6378137
> es : 0.006694380022900787
> lat_0 : 46.5
> lon_0 : -66.5
> k : 0.999912
> x_0 : 2500000
> y_0 : 7500000
> towgs84 : 0,0,0,0,0,0,0
> no_defs : defined
> -PROJ_UNITS------------------------------------------------
> unit : metre
> units : metres
> meters : 1
> Maciek
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
