[GRASS-user] v.transform - output messages
Maciej Sieczka tutey at o2.pl
Sun Oct 15 08:09:16 EDT 2006
Helmut Kudrnovsky wrote:
> i want to move a large polygon-layer by "v.transform " with the following options:
> v.transform
> input=schiechtl_stern_m28
> output=fwoe_mm28_tf45
> xshift=-450000.0
> yshift=0.0
> zshift=0.0
> xscale=1.0
> yscale=1.0
> zscale=1.0
> zrot=0.0
> so a -450000m-shift on the x-axis,
> when i start, i get the following
> output-messages:
> V_ask error: Illegal row (40) in call to V_const
> what do this messages mean?
I don't know but it's not normal I would say. If you could reproduce
that with sperfish60 and submit a bug report with how to reproduce
instruction it could incline some Grass developer to fix it. Could you?
> p.s. is there something similar like v.transform for raster data to move/shift raster data inside grass?
r.region. But it's not that straight-forward as v.transform - you have
to manually calculate the region bounds (N,S,E,W) given the shift you
need, then apply this new region bounds to your raster.
Maciek
