[GRASS-user] new r.in.xyz Benchmarks
    Patton, Eric
    epatton at nrcan.gc.ca
    Mon Oct 23 14:26:45 EDT 2006
Hi all,
Good news with r.in.xyz. This program is really performing. I ran the
following tests:
Input file: 2006_Garry_Trough_1.txt
Time to Import: 8min, 24sec.
# of Points: 100,055,397
Input File: 2006_Garry_Trough_2.txt
Time to Import: 9min, 22sec.
# of Points: 115,947,033
Input File: 2006_Garry_Trough_3.txt
Time to Import: 10min, 33sec
# of Points: 126,162,261
This is really fantastic. Before, I had to chop each input file into 1GB
sections using awk, import, then patch back together. I couldn't even script
that, as I was getting the double free/corruption errors, which have
altogther vanished.
I'll be able to test it even better in about a month's time, as I'm getting
massive LIDAR dataset that was just flown - about 0.25m resolution, at an
area of about 5km X 15km - all in xyz format! ;)
Thanks!
~ Eric.
