[GRASS-user] RPMs available for GRASS 6.2.0RC3
Markus Neteler neteler at itc.it
Tue Oct 24 18:36:13 EDT 2006
I have build Fedora FC4 RPMs on OSGeo's telascience machine
which are hopefully compliant to other 32bit distros:
http://grass.itc.it/grass62/binary/linux/
For easier installation, I have also put PROJ4, GEOS, GDAL
and GRASS-GDAL-OGR plugin RPMs there.
cheers
Markus
On Tue, Oct 24, 2006 at 12:43:01AM +0200, Markus Neteler wrote:
> Dear all,
> the hopefully final release candidate GRASS 6.2.0RC3 has
> been published. The following fixes have been done:
>     * r.le.setup fixes (Glynn, Hamish)
>     * default color map range (bug #5212) (Glynn)
>     * fix v.digit/toolbox.tcl for tcl8.3 (Hamish)
>     * update to EPSG 6.11.1 (Markus)
>     * close GRASS after creating new location from file (Markus)
>     * Fine tune intro text when launching GRASS in text mode (Paul)
>     * gis.m zooming in mapcanvas.tcl (Michael)
>     * missing Polish EPSG codes (Frank, Maciej)
>     * initial Arabic translation (A. Masoud)
> See also:
> http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#RC3
> Please continue to test, especially gis.m. This release candidate
> should be very close (or even almost identical) to the final
> release of GRASS 6.2.0.
> Thanks to all contributors - coders and testers!
> Markus
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
