[GRASS-user] Installation problem
gotnidea! Business Development Centre gotnidea at gmail.com
Fri Oct 27 10:07:01 EDT 2006
Hi again
IIn my version of GRASS, I am unable to locate 'GIS' and 'Display' options
in the menu. Nor am I able to generate any display in the Map display. It is
totally blank!
I have followed all the steps given. How can I view the maps? I am working
on Spearfish60 data with GRASS6.3 version on Windows Xp SP2.
There is one 'Configure' option in the Menu through I was able to generate
the following details:
g.region -p
projection: 1 (UTM)
zone:       13
datum:      nad27
ellipsoid:  clark66
north:      4928010
south:      4913700
west:       589980
east:       609000
nsres:      30
ewres:      30
rows:       477
cols:       634
cells:      302418
g.gisenv
LOCATION_NAME='spearfish60';
MAPSET='user1';
DIGITIZER='none';
GISDBASE='C:/GRASSDATA';
GRASS_GUI='tcltk';
g.proj -c
d.info -r -d -f -b -c
rectangle: 0 643 0 484
dimensions: 643 484
colors: 16777216
frame: 0 643 0 484
region: 0 643 0 483
Couldn't locate the problem on any of the forums. Anyone please help me.
Abhinav
On 10/27/06, gotnidea! Business Development Centre <gotnidea at gmail.com>
wrote:
> Thanks again Moritz,
> I changed the address of postgres link in grass bat file file to my d:
> postgres installation. GRASS is opening now.
> I would now work on some tutorials and get back if I require any help.
> Thanks again
> Abhinav
>  On 10/26/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> > switched this to wingrass list...
> > gotnidea! Business Development Centre wrote:
> > > Thanks Moritz
> > > I have installed postgresql on my D: ( NTFS one).
> > > Now I have one more problem. I searched it over mailing list
> > > archives. It is quite similar to the one at:
> > > http://www.nabble.com/grass-not-starting-tf2417646.html#a6739510
> > Dilnesaw Alamirew wrote:
> > > 1) pop-up window:
> > > error in startup script
> > > can't read "parts(n)": no such variable while executing
> > > "MapCanvas::zoom_new $mon $parts(n) $part(s) $parts(e) $parts(w)
> > > $parts(nsres) $parts(ewres)" (procedure "MapCanbas::zoom_greion" lin
> > > 11
> > > line 40, line 11, line 69, line 30 mentioned. Unfortunately the error
> > >  message could not be copied.
> > This normally means that pg.dll cannot be found and that g.proj fails.
> > Is PostgreSQL correctly installed ? Is the path to it correctly defined
> > in grass.bat ?
> > > 2) shell: STARTIN GRASS ....
> > > Warning: Attention! Warning: Look is not supported onWindows!
> > > I have a GRASS shell but no GUI.
> > Do you see any other error message ? The warnings have nothing to do
> > with this.
> > > If I define a new location/mapset I get syntax error after "short
> > > description" promot - input not recognised, even though it is mainly
> > >  only y or n.
> > > If I define a new location/mapset from a georeferenced file I get:
> > > Application error: channel console 2 wasn't opened for writing.
> > Currently definition of new location from georeferenced file or from
> > projection values does not work in wingrass.
> > > The only problem is that I couldn't get any workable solution. I am
> > > working on spearfish data. I would love if any one could guide me to
> > > any tutorial on the same.
> > Which of the above problems do you have ? Please describe exactly what
> > you do and what error messages you see.
> > Moritz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061027/6de1f883/attachment.html
