[GRASS-user] Re: New comer's difficulty [was] r.spread not finding
spread time
H.S.Rai
hardeep.rai at gmail.com
Mon Oct 30 00:02:39 EST 2006
I, as a new comer to GrassGIS, trying to learn by reading online
instruction and using related dataset. But I find those tutorial are
written for Older Version and thing are not working as such. So, If I
am able to go through with the help of list members, then I will
rewrite or post comments, so that newcomer may take a smoother ride.
So, I request knowledgeable list member to solve following problem.
Thnaks in advance.
H.S.Rai
On 10/27/06, H. S. Rai <hardeep.rai at gmail.com> wrote:
> I was trying firesimulation data on grass6.2.0RC3, and following
> commands never stopped:
> r.spread -vds max=my_ros.max base=my_ros.base dir=my_ros.maxdir
> spot_dist=my_ros.spotdist w_speed=wind_speed f_mois=1hour_moisture
> start=fire_origin lag=95 backdrop=image_burned output=my_spread
> x_output=my_spread.x y_output=my_spread.y
> 100%
> Reading inputs ... 100%
> Reading fire_origin ... 100%
> Finding spread time - number of cells visited in percentage ... 0%
> That mean. it could not find spread time, this 0% remain 0%.
> Do i change some parameter or value in above mentioned command?
> The g.region -p showed following information:
> projection: 1 (UTM)
> zone: 18
> PROJ_INFO file not found for location firedata
> datum: ** unknown (default: WGS84) **
> ellipsoid: a=6378137 es=0.006694385
> north: 4391490
> south: 4385100
> west: 547000
> east: 551890
> nsres: 19.96875
> ewres: 19.95918367
> rows: 320
> cols: 245
> cells: 78400
> Is PROJ_INFO file a problem. If yes, how to make it.
> Thanks in advance.
> H.S.Rai
H.S.Rai
